Active Directory
AD Recovery Testing: How to Know Your Recovery Plan Will Actually Work
Prepare your team to confidently face an outage.
When Microsoft Active Directory (AD) goes down, business operations grind to a halt. Users are locked out, and critical systems become inaccessible. The impact of such downtime can be severe, leading to lost productivity, revenue, and even reputational damage.
This is why having a robust AD recovery plan is crucial. But how can you be confident that your plan will work when it matters most?
The answer is simple: frequent testing.
Why AD Recovery Testing Matters
AD is the core identity and access infrastructure for most enterprises. In the event of an AD outage – whether from ransomware, corruption, or administrative error – the ability to quickly and accurately recover AD is essential for business continuity.
Regularly testing your AD recovery plan delivers confidence that recoveries can be successful and allows security and IT teams to practice during good times to prepare for the bad times.
What’s at Risk Without Testing?
Failing to test your AD recovery plan regularly puts your organization at risk:
  • Extended downtime: Recovery takes far longer than expected, prolonging disruption.
  • Security exposure: Rushed, incomplete recoveries may introduce vulnerabilities or open the door to repeat attacks.
  • Data loss: Critical data may be irretrievably lost if the recovery process is flawed.
Core Components of a Reliable AD Recovery Test
1. Simulate Various Disaster Scenarios
Test recovery under the same pressure and constraints you’d face in a real incident. That means simulating scenarios such as schema corruption and ransomware encryption. Only through carrying out a holistic AD recovery will you identify gaps in your recovery plan.[DC1]
2. Test in an Isolated Environment
  1.
Recovering to an isolated, non-production environment will provide valuable insight into the completeness of the recovery plan and allow you to vet your own recovery procedures.
3. Test and Update Recovery Plans Regularly
Regular recovery testing is not a one-time task but an ongoing process. Consider testing your AD recovery plan every 3–6 months. Use these tests as an opportunity to both validate your plan and update the recovery guidance based on any recent changes to the AD architecture or topology. Keep your documentation up-to-date and make sure that all team members are trained on the latest procedures.
Common Pitfalls to Avoid
  • Assuming backups are enough.
  • Only testing partial recovery scenarios.
  • Lacking visibility into backup health and scope.
  • Not aligning recovery priorities with business impact
  • Determine your minimum viable AD required to support the organization and plan accordingly.
Confidence Comes from Testing
Prioritizing regular, automated, and comprehensive recovery testing is critical for gaining confidence that your AD recovery plan is effective. Don’t wait for a real disaster to find out your plan doesn’t work.
Ready to Test with Confidence? Learn how Commvault helps organizations validate their recovery plans and get back online faster, with confidence. Explore AD recovery solutions.
Learn More
Check out these other blogs in our Active Directory series:
Watch our on-demand webinar “The Naked Truth” to see experts simulate a real-world Active Directory outage and demonstrate rapid restoration techniques.
Thumbnail_Blog_Ready-or-Not-Ep2-Hack-or-Hype-with-Joseph-Menn
Hack or Hype with Joseph Menn
Read more about Hack or Hype with Joseph Menn
Thumbnail_Blog_Ransomware-Protection-AirGap-2025 (1)
Meet the Defenders: The People Behind Cybersecurity at Commvault
Read more about Meet the Defenders: The People Behind Cybersecurity at Commvault
Thumbnail_Blog-Recovery-Starts-with-Visibility-2026
Recovery Starts with Visibility
Read more about Recovery Starts with Visibility
